Beth Safranski
Is there a way to use several boundaries with the offset surface function?
Discussion created by Beth Safranski on Jun 18, 2019
Latest reply on Jun 22, 2019 by Beth Safranski
I am using the Macros offset surface command.  It appears to work well when I have a single clipping boundary and use it in the command on creation.Macro offset surface with clipping boundaryWhen I then try to add several surface boundaries (Undefined elevation), the surface changes drastically.
Several BoundariesMacro Offset Surface after boundaries added
I am using TBC 5.1.  I tried installing the Trimble macros SDK file and that didn't seem to help.
