Coordinate Transformation of VCL Files
Question asked by John Mill on Jun 23, 2019
I have numerous TBC jobs generally by daily Surveys (over the last 3 years) from which I've extracted VCL Project Link as I want to retain Photographs with their associated As Builts,
I've then imported these Job Link files into a "Combined Job" for a compilation to produce an As Built set of data (both Plan and electronic),
The Client requires the Data Sets in two seperate Coordinate Systems (the Design Set and basically a GIS Set for the Local Council) - NZ Mt Eden Datum 2000 and NZTM Datum 2000 directly linked.
If I change Coordinate Systems in project explorer the imported Objects/points won't transform (but an imported csv file will)
Error meesaage "Some Points could not be computed due to transformation errors. Check your actual coordinate system settings"
I have gone back to the "source" TBC jobs and I can Transform the data OK in those.
As a seperate issue also DXF/DWG CAD Files imported won't transform either - they're underlying Cadastral Data sets
Any suggestions please?
