In the report utility it shows the Antenna Height as 6.562, even when the quick release is enabled, shouldn't this be 6.692? Without looking at the Report tab to see if they have a quick release enabled when they setup, is there a way to add an option in the Record tab that shows if the quick release was enabled or have the antenna height show the actual height, 6.692, with it enabled?
If I have to dig through their report to see if its enabled I could basically be guessing if they had it enabled or not and my elevations could be off if I have to change the elevations of the shot I would like to know the actual height of the rod they had at that moment.
Let me know if this doesn't make sense
I can confirm that the RU will only display a height of 2m, or whatever rod height was entered into SCS/Siteworks at the time of the measurement, or the "user-entered antenna height". The Quick Release is correctly accounted for, however it's not displayed anywhere. Unfortunately this means that the only way to tell if the QR was used is by looking at the task log.
I've added this ability to display and more effectively record if a QR was being used to our feature backlog for Siteworks. Note that when this functionaliy comes out it will only be in Siteworks and not SCS900, as SCS900 will not be developed and the future of SPS software is in Siteworks.
