I upgraded my TBC to version 5.10 and now I get these error messages when I try to create machine files. I have tried removing and re-downloading the program but I still get the error messages, also tried different GCS900 export versions. Any ideas would be appreciated.
Hi Kris,
I had the exact same problem when installing 5.10. When installing, the window to install .NET Framework came up and due to user permissions on my work laptop would not install. Once I was able to install it, TBC ran fine. I asked the IT admin to allow the install of the .NET Framework, and it installed fine.
Trimbles response to the question was:
TBC requires the install of Microsoft .NET Framework 3.5 SP1, 4.62 and 4.7.2.
To manually install .NET Framework 3.5 SP1, open the Control Panel and select Programs and Features. Then select "Turn Windows features on or off" and select the Microsoft .NET Framework 3.5 check box. This option requires an Internet connection.
The .Net 4.62 and 4.7.2 Installers can be found in:
C:\Trimble Downloaded Installations\Trimble Business Center 5.10\NETFX462 C:\Trimble Downloaded Installations\Trimble Business Center 5.10\NETFX472
For more details please refer to pages 5 and 6 of the Enterprise deployment guide.
If this does not work then they might need to get an IT specialist to look at their PC.
Hope this helps!
