Improvements to the camera button
Question asked by Kenneth Eggan on Sep 17, 2019
Hi!
I was wondering if you could do some improvements to the camera button (Export current 3D view as image)?
Our user case is building brudges in Norway - which involves a lot of bad weather and cold winters. As of today, we have not found any good digital, weather and temperature proof solutions for bringing the BIM to the construction site.
An easy, and well-known solution would be to print views from Trimble Connect.
The only in-build solution I have found is the camera button, which partly solves our need.
The ideal solution to this would be a print button which captures the view, and the attributes (if selected) and prompts the print dialog box.
Is this something you would consider implementing to Trimble Connect Desktop?
Thanks!
