how to change ifc settings for TC plugin? Now TC Tekla plugin is exporting much information which are irrelevant. And some of them are missing.
Is it possible to have IFC settings customized when synchronizing the model with TC ?
Hi Marcin,
You can set up your IFC settings in Tekla in the IFC settings screen.
Then save these settings.
Then you can press cancel in this screen.
After that, start up the Trimble Connector and select the desired IFC settings.
Help that this solves your question.
Best Regards,
Tom
