Elevation edit that does not move graphics
Question asked by Kurt Crispin on Nov 4, 2019
Latest reply on Nov 5, 2019 by tim_mcclannahan@trimble.com
I have created a surface for a cul de sac using arcs that were then given elevation to contour the Cul De Sac.
The engineer has come back to modify the cul de sac raising it 1.5 feet and instead of sheeting at 2% across the surface he has rasied the Centerline Profile.  I have tried to just change the elevations at the end of each arc that makes up the Edge of Pavement of the Cul De Sac.  The edit command seems to work but the graphic does not move.  I get two points that when I draw a line between them the line is .18  but both items report that they are at the same elevation.
not a .18 difference.
