Hey,
i want to import some data to a sector profile from an excel table and all works fine except for the "sector type" - token. For testing i exported the data to excel and reimported them to tilos and all data got imported except for the sector type. So is it not possible to do this? (This would be not very good, because then you have to set the sector type for every sector by hand..)
I have many more questions, but the community seems to be very small, so is there a contact person to whom i can write my problems?
Btw. i'm using tilos in german.
Kind Regards
Phil
Phil,
Doing so is possible and we just tested it in a recent build to ensure it works. Two steps to remember on this workflow include: 1. Sector type column is "ticked" in the import dialog 2. Sector type is matched by the full name, so it has to be correct
With regard to your other questions, its best to speak with whomever you purchased the software from. If your in Germany, I presume that is Peter - write him a mail and let him know what you need. Our expert training staff is based in Germany, so you should have no problem getting the additional help you need.
Cheers,
TILOS
