I would like to know how to load a drawing in DXF format to my R-10 rover with a TCS3 data collector to use as a measurement boundry (while in the measurement mode)
easy! few options-
Good morning alan
thanks for your reply,the Dxf file is in my tcs3 data collector.
My question is how can i see it on the measurement screen (so that i can see the survey boundaries while topo measurement)
You need to add the DXF file as an active map, through the Properties of the job.
Or from the map screen , up arrow>layers
Good morning
Thank you very much
I loaded the map successfully
Best regards
Avi shaham
נשלח מה-iPhone שלי
אבי שחם
מודד מוסמך
054-3171132
easy! few options-
