Feature Request - Create Point Feature Coding
Question asked by Josh Weckert on Nov 27, 2019
Latest reply on Nov 28, 2019 by Alan Sharp
In the create point command the feature code can be entered manually or the cumbersome feature code editor can be opened to find codes
Trimble Access again far outshines TBC here
In Access when tapping  in the code field a dialog box pops up where you can sort and dynamically search by either code or description.
The measure codes functionality in Trimble Access is a great feature and a configurable measure codes dialog box under the code field would be a huge addition. Much better in the create point command compared to a separate TML
Measure codes also has template pickup, the +/- for quickly changing string numbering and find getting the next free string number.
