Is the Makro "Explode IFC Shell" faulty?
Question asked by Andy Frei on Nov 27, 2019
Latest reply on Dec 6, 2019 by Andy Frei
Seems like "Explode IFC Shell" with option "include all does explode the IFC-Object into line segments, but the IFC-Objects remains (=good).
Saidly all the other filters do not work at all:
- Normal "up": would expect to create a surface, triangles or-at-least-lines at the top of the IFC-Object
- Normal "up": would expect to create a surface, triangles or-at-least-lines at the very bottom of the IFC-Object
- Vertical face: would expect to create lines along the vertical sides of an IFC-Object
- As well the option "create CAD-Points" does not do anything either, in none of the available Filters
Attached you can find an IFC of a House where I was testing with. I would have liked to see the bottom of the foundation object to be extracted into usable objects.
I wonder if we will see an option to create surfaces directly out of an IFC Object (either top/bottom) with eliminated verticalities, so that that can go directly onto a rover/machine...?
