Editing Templates in Trimble Connect
Question asked by Gaylynne Carter on Dec 10, 2019
Latest reply on Dec 11, 2019 by Gaylynne Carter
Hi
Basic question but can't seem to find an answer on Google.... Is it possible to edit the geometry settings on a published or for that matter copied template? I have an erroneously assigned point that needs to be an area. The long solution is to create a new template to correct that one issue, but there are actually a couple of them and there are multiple fields etc to them so as a one off fix  - OK - but there must be a better way... .
I'm using Trimble Connect not Insphere so it looks quite different -  (I'm sure I could easily do this using InSphere...)
I've opened what looks like it should be the editing tool - below -, it seems to let me change fields etc but not geometry.
I'm sure tee is an easy and obvious solution!
Please help.
