Project Cleanup - Remove Duplicate Lines - Set priority or file to keep data
Question asked by Patrick L'heureux on Dec 30, 2019
Is there a way to set the priority of which lines to keep when running remove duplicate lines? i.e. If I import two files and they both have existing contours, can I set which file should keep the line work and which should get dumped.
If not maybe a TML or separate command that would allow you to:
  • Select selection sets to process
  • Set priority level on which set will keep data and which will dump data
  • run remove duplicate linework
enhancement request
