Ben Wall
Feature Request - List Elevations when using Contours by Crossing
Discussion created by Ben Wall on Dec 31, 2019
Latest reply on Jan 7, 2020 by Ben Wall
I use the contours by crossing command a lot when working with pdf files but I'm constantly stopping to double check that the contours are set correctly  with the properties window.  It would be very helpful for me for the command window to produce a list of contour elevations that have been raised to grade with the last run.  Something similar to the results/history window in the Measure Distance command.  The user could quickly glance and see everything is being raised correctly.
