Base setup on R10 via Bluetooth from TSC3 controller clears all Bluetooth ports
Question asked by Tony E on Jan 20, 2020
Latest reply on Jan 20, 2020 by James McWha
We have designed an application to read NMEA data from a R10 via NMEA over Bluetooth ports.  Everything works as long as the ports are setup to export the NMEA string via Bluetooth correctly.  However we have recently found that when we have to change the base on a R10 and connect via TSC3 over Bluetooth it wipes all the Bluetooth ports.  Is there a way to keep this from happening?  The app is designed to read from any of the ports as long as one is setup correctly still so even if it wiped the first port that it is using to connect that would be okay, the other two getting wiped as well is the issue.
