REVIEW JOB REPORT
Question asked by DeWayne Manon on Jan 21, 2020
Latest reply on Feb 13, 2020 by Rhett Wheeler
I am looking for, or want to create a REVIEW JOB REPORT or style sheet.  A report of everything done on a .job from x date to y date.  hoping for a cleaner version of the FBK FILE.xsl or SURVEY REPORT.XSL looking something like this
JOB NAME:        DATES IN REPORT:
5670-03-00 WO #5 STH 24        10/22/2020
_______________________________________________________________________________
COORDINATE SYSTEM:        UNITS:
Rock (United States/Counties/WCCS)                                                              U.S. SURVEY FEET
SCALE FACTOR 1.00000000        INTERNATIONAL FEET
IF SITE CAL:
FIX H. SCALE TO 1.0:  YES or NO       VERT. ADJ.: CONSTANT or INCLINED PLAIN
GRID POINT        GNSS POINT       H. RESID.              V. RESID.              USE
1                              101                         0.02                        0.00                        H & V
2                              102                         0.02                                                        H
4                              104                         0.03                                                        H
6                              106                         0.02                                                        H
NAME OF SURVEY STYLE STARTED:                Conventional       or         GPS/GNSS
IF SURVEY STYLE: GPS/GNSS
SURVEY CONFIG               ROVER OPTIONS
SURVEY TYPE: RTK                            BROADCAST FORMAT: VRS (CMR)
ANTENNA TYPE: R10                       MEASURE TO: BOTTOM OF QUICK RELEASE
HEIGHT: 6.562SFT                             PART No. 90900-XX
STORE AS: VECTORS                        ELEVATION MASK: 15°                    PDOD MASK: 4.5
GPS: Y   L2e: Y    L2C: Y    L5: Y       GLONASS: Y       GALLILLEO: Y QZSS: Y      BeiDou: Y             xFill: Y   Tilt: Y
Base Point: PRS547128948949
IF MEASURE POINTS
PT #, NORTH, EAST, ELEV, DESC, ROD HI, # SATS, H, V, EPOCS, PDOP, RMS
IF STAKE OUT
DESIGN PT #, NORTH, EAST, ELEV, DESC, AS STORED PT #, NORTH Δ, EAST Δ, ELEV Δ, ROD HI, # SATS, H, V, EPOCS, PDOP, RMS
IF A POINT WAS OBSERVED MULTIPLE TIMES SHOW EVERY OBSERVATION AND AVERAGE
NAME, CODE, NORTH, EAST, ELEVATION, ANT.HGT., # SATS, H, V, TIME, EPOCH, RMS
IF SURVEY STYLE: CONVENTIONAL
ATMOSPHERE    PPM -8     PRESSURE 28.56inHg    TEMP: 30.0F       CURVATURE: N    REFRACTION: N
STATION: 1          HI:5.02 Bottom notch     BS: 2      HI: 4.78                H Δ, V Δ
IF MEASURE POINTS
PT #, NORTH, EAST, ELEV, DESC, ROD HI, PRISM O/S, H. ANGLE, V. ANGLE, H DIST
IF STAKE OUT
DESIGN PT #, NORTH, EAST, ELEV, DESIGN DESC, AS STORED PT #, NORTH Δ, EAST Δ, ELEV Δ, AS STORED DESC, ROD HI,
IF STATION
DESIGN PT #, STATION, H OFFSET, V OFFSET, Construction offset, ELEV, DESIGN DESC, AS STORED PT #, NORTH Δ, EAST Δ, ELEV Δ, AS STORED DESC, ROD HI,
IF STAKEOUT LINE
                START POINT, END POINT, STATION, OFFSET, CUT/FILL, ELEVATION, CODE
IF COGO – COMPUTE POINT OR STORED INVERSE
SHOW HOW IT WAS CREATED
Anybody know how to create this style sheet/ report or is it out there already?
Thanks
DeWayne
