DA1: 5Hz update with SV-based RTX
Question asked by Will Dimmit on Feb 18, 2020
Latest reply on Feb 19, 2020 by Nico Becke
With a DA1 antenna, I can request a 5Hz update rate when using an autonomous or SBAS solution using the following code:
Once I've started a survey using RTX, 5Hz solutions seem to be available unless the app has to fallback to SV-based delivery of these corrections.  In that case, the solution rate is reduced to 1Hz.  Is there any work around for this?
