Generate XYZ from linestring/surface intersection
Question asked by Lasse Hanberg on Feb 21, 2020
Latest reply on Feb 28, 2020 by Brent Cofer
Is there a workaround to generate a point (XYZ) where a linestring intersects a given surface model?
I can get it from the profile viewer, or use the "Create Surface Intersection" which kinda does it.
But, both only work on one line/point at a time, and we need it to happen across multiple, possible hundreds to be effective.
If we could trim the lines to a surface, instead of just a bounding line, we could use the "Create Point at Intervals" and then sort out the points we need - so who's got a macro for that :-)
