Release date: 15.02.2021
FIXED: Going to editmode in Road tasks was slow in Quadri models with many alignments.
FIXED: Quantity report from the task could in some cases cause a crash.
FIXED: Line tasks of type 'Non-Alignment Line' would loose the alignment geometry when importing one Quadrimodel into another or using QG4 import.
FIXED: The dialog could freeze when editing the alignment in other visual styles than 2D Wireframe inside the CAD-software. Now Alignment Design will force the visual style to 2D Wireframe while editing, then return to the previous visual style when finishing Alignment Design.
FIXED: If user applied illustration symbols in the cross-sections then the terrain cross-sections and calculation gave the wrong results.
FIXED: Editing Road tasks used as Calculation Basis did not send the user to the description of the external model.
FIXED: Softspot removal with simple method did not remove the layer properly under the road where it was not in contact with the layer.
FIXED: Draw Cross-sections where there was no data to draw could cause issues. Users now get a warning about changing the settings instead.
FIXED: Layermapping table in the Quadri function 'Export to DWG' would list the first part of the layer mapping twice when using “VegOgJernbaneTilDwg” presentation setup.
These are the changes done in addition to what has been done for Novapoint Road.
FIXED: Drawing railway alignments didn't get the elevations that the drawing style “Luxembourg Axe En Plan” is supposed to show.
FIXED: The update function for trench bottom level to follow lowest pipe, did not update all trench sections correctly.
TSLINE - Improved how line and symbol is updated when user move the attached sign (#HAN-3454)
834.x - The contents were not placed correctly on the sign (#HAN-3454)
FIXED: Error when transferring plan from CAD to Quadri.
