Quadri
Quadri 2020.FP1A Release Notes
01-03-2021 12:05
If you use Model Server, this version can only be used with Model Server 3.0 or newer.
Models created with earlier versions of Novapoint, will be converted on opening in Quadri 2020 and can ONLY be used in Novapoint 21 and Quadri 2020, and it will not be possible to open it with earlier versions of Novapoint after conversion.
Quadri 2020.FP1A
Release date: 13.11.2020
Click here for information about Known issues and Compatibility Breaks.
Quadri for Windows
International Version
General
FIXED: Timestamp not stored when editing Class task.
FIXED: Issue with duplicate features when reimport old Civil3D connector task on new version.
Import
FIXED: Some imported DWG solids get a strange geometry after import.
FIXED: Not adding themecode in KOF import, when points have a name.
IMPROVED: The DWG import seems to hang (does not finish) if the value is 0 for “Max face edge length”. Value 0 is default value for:
  • Best Performance
  • Best Quality
