Jan 04, 2021
Trimble Connect for Browser
2.97
Tekla Online Organization Admins will now be able to access Trimble Connect’s Account admin portal.
The user dropdown in Connect will display Account Administration option
If you are admin for multiple accounts, then the Tekla Online account will also be listed. Else you will be redirected to the Users listing page.
File metadata attributes can be defined. These custom attributes will reflect in Connect’s files listing in projects which are using a license from the account.
Learn more about project ownership here.
Learn more about File Attributes ›
Property Set Master Libraries can be defined (usage of this feature in projects requires Business Premium).
The admin will be able to assign Account level libraries to projects.
Learn more about Property Set Master Libraries ›
Connect will not handle licensing or role changes for Trimble Subscription accounts or Tekla Online accounts. Any change to role or licensing can be done from the Account Admin Portal or the Tekla Online portal. The admin can navigate to correct portal using “Manage Licensed Users” .
Note: This change does not apply to Enterprise Accounts.
Learn more about Internal Users ›
