Hello Everyone,
Trimble Connect for HoloLens v 3.1.1 is now available in the Microsoft store and can be downloaded on to your XR10s/Hololens 2. The focus of this release is to improve the QR Login process for the user.
This version should be paired with Trimble Connect Mobile v 2.12.2 available on play store that has a fix for the Hololens Companion with varying background for the QR code. This will help you login to the Trimble Connect Hololens app regardless of environmental lighting conditions.
NOTE : The iOS release to App Store is blocked due to the need to have “Sign in with Apple”. The TCM team is working on the changes needed.
TCH v 3.1.1 + TCM v 2.12.2 = Improved QR Login
What is new/updated in this release of TCH?
- QR Code Login: Updated Scan Frame & Re-adjusted Auto-focus to improve QR code login.
- Minor UI/UX improvements/Enhancements
- Bug Fixes
Important Note: Due to significant changes in functionality between HoloLens 1 and 2, all releases of Trimble Connect for HoloLens v 3.0 onwards are developed exclusively for Microsoft HoloLens 2 and Trimble XR10 with HoloLens 2. New versions will not be backwards compatible with Microsoft HoloLens 1.
