There is a new version of the Trimble Connect for Windows application released today. Version identifier for this release is 1.11. The new version is available for download in the Connect apps store page or by clicking the "New version available!" button in the top right corner of the Connect for Windows application.
At the time of writing, the SketchUp 2021 model format support is only available when the model files are uploaded using the Connect for Windows 1.11 application. If a SketchUp 2021 model file is uploaded using any other application, like the TC for Browser or the TC Sync applications, the file cannot be viewed in 3D in Trimble Connect. This is because the SketchUp 2021 conversion is only available in the local Windows application processing. We’re working to introduce the SketchUp 2021 conversion support also to the cloud processing as soon as possible.
Also note that until the SketchUp 2021 cloud processing support is introduced, it may be necessary to manually retry the model file conversion to view SketchUp 2021 models in the browser. Should you experience any problems with viewing SketchUp 2021 model files, make sure to run the “Retry file conversion” command from the Models panel in Connect for Windows 1.11. The command is visible in the context menu for project admins:
#Release_Notes
#Trimble_Connect_Windows
#Trimble_Connect
I like being able to get a point coordinate, but my point cloud (laser scan) no longer clips to a clip plane. Is this a functional change?
