DA2 and M300
  • 1.  DA2 and M300
    Posted 04-09-2023 16:25
    Hello, Is it possible to use my DA2 antenna to connect on my M300 RTK Custom System?
    For this, the following information are necessary: NTRIP Host, Port, User, Password and Mountpoint.
    Thank you very much.
    Lorena Lacerda
  • 2.  RE: DA2 and M300
    Posted 04-10-2023 09:10
    Hello Lorena,
    The DA2 cannot be used as a base station in an RTK setup.  You can, however, use the DA2 as a rover with your own base station.
    Simply use Trimble Mobile Manager to configure the necessary NTRIP settings to access the correction stream.
    Dan Colbert
  • 3.  RE: DA2 and M300
    Posted 05-15-2025 15:39
    If you are using Field Maps with the DA2, does your base station receiver head need to be compatible with Field Maps, or can it be any receiver head that can be configured as a base station?
    Brent Crain
  • 4.  RE: DA2 and M300
    Posted 05-16-2025 05:23
    Hi @Brent Crain
    The Catalyst DA2 only supports real-time corrections with Fieldmaps.
    • This can be delivered through either the Trimble Correction Hub (which provides global corrections with either Trimble VRSNow or RTX) included in your subscription
    • Or a local NTRIP
    • If you're able to setup a local NTRIP with your GNSS equipment then of course this can be used as a real-time correction source. You'd need to configure it via Trimble Mobile Manager
    If you're looking at post processing against a base then this is not supported at the moment unless you are using Trimble Terraflex
    Take a look at the help portal for more details and bookmark the configuration guide to help get your head around how Fieldmaps connects to your Trimble GNSS receivers
    Tom Harrison
