Extract .jxl via the Connect API
  • 1.  Extract .jxl via the Connect API
    Posted 08-26-2025 23:45
    Is it possible to extract the .jxl automatically from Trimble Connect through the Connect API? The reason for this is that they want to implement automatic extraction of the .jxl uploaded from the surveyor and use that file to do automatic geometric/geodetic control of the measured data.
    Best Regards
    Snorre
    Norgeodesi AS
    Norway
    Snorre Randen
  • 2.  RE: Extract .jxl via the Connect API
    Posted 09-02-2025 17:19
    Hi @Snorre Randen,
    The Jobs API performs feature extraction when a job file is uploaded, making the JobXML file available for you to download through the attachments endpoint.
    "On Add/Update Job Attachment if the file being uploaded is a Survey jobType, tagged as a "RootDataFile" and a JOB with "Resolved" status - then a Feature Extraction process is triggered. The Get Status route can be used to check the status of the Feature Extraction process."
    Field Systems Data Services | Field Systems Data Services | Developer Documentation (trimble.com)
    Chris Warren
