Machine Control - Parabolic Crown?
  • 1.  Machine Control - Parabolic Crown?
    Posted 05-28-2021 16:42
    We have started a project that will be running grade control on a dozer and motor grader.  This roadway is a 6" parabolic crown with two 8' section at different cross slopes.  I have the idea for lane guidance.  I belief the operators are not trained on using this feature.  So it maybe slow process for them to learn.  I also had the idea to extend the first 8' section at the crown by 4' then leave a 1' void and start the next 8' section of the parabolic crown.  This way the blade doesn't try to rollover n the next break.
    Anyone felt with parabolic crown design in the grade control?  How did you tackle the design?
    Francisco Guerrero
  • 2.  RE: Machine Control - Parabolic Crown?
    Posted 06-01-2021 21:23
    How you supposed to create an eight foot arc with a 12' straight moldboard?
    Mark Matthews
  • 3.  RE: Machine Control - Parabolic Crown?
    Posted 06-02-2021 04:05
    This is done this way to cut grade using a detail provided.  The grade cutting will be done is straight segments.
    Francisco Guerrero
  • 4.  RE: Machine Control - Parabolic Crown?
    Posted 18 days ago
    We've worked with similar parabolic crown designs, and the key is creating a smooth transition between cross-slope sections so the blade doesn't roll over. Extending the first section and adding a small transition can help, especially for operators still learning lane guidance. We handled this by adjusting the model and testing with a used motor grader to achieve a consistent crown.
    Ellen Jackson
