Surface Slicer View
  • 1.  Surface Slicer View
    Posted 11-27-2022 03:19
    Is there a way to change vertical scale in the Surface Slicer view?
    If yes, how?
    Thanks.
    Saif Bin Darwish
  • 2.  RE: Surface Slicer View
    Posted 11-27-2022 14:13
    CTRL + SHIFT + SCROLL UP/DOWN
    Marian
  • 3.  RE: Surface Slicer View
    Posted 11-27-2022 20:17
    Thank you so much.
    The information transmitted through this mail is confidential and may be legally privileged. Access to this mail other than the intended recipient is unauthorized. If you are not the intended recipient, please notify us or erase contents. Any re-transmission, dissemination, action or omission based on the content of this mail by persons other than the intended recipient may be unlawful and strictly prohibited. We monitor email communications through our network. Any violation for the above norms may lead to prosecution.
  • 4.  RE: Surface Slicer View
    Posted 11-28-2022 08:42
    The scale can be modified from the case parameters, "View" tab > "Cross-sectional view" (sorry, my TBC is in French):
    Kévin SOULARD
  • 5.  RE: Surface Slicer View
    Posted 11-28-2022 21:27
    I think you are referring to "profile View".
    I am checking on "Surface Slicer View".
    Thanks.
    Saif Bin Darwish
  • 6.  RE: Surface Slicer View
    Posted 10-30-2025 21:44
    Speaking of the Surface Slicer View (3 years later!), what is there no ability to select from this view. It would be super helpful to select in the surface slicer view to more effectively clean a surface. Especially, one that is produced from drone-derived lidar. The vertical exaggeration in the 3D view is nice for this; however, it would be ldylic to select from the slicer view! I may be missing something but I have looked everywhere in settings, options, and on the web. Perhaps I can try the profile view?
    Zach Edwards
  • 7.  RE: Surface Slicer View
    Posted 11-06-2025 07:09
    If you are simply wanting to select a section in the slicer view (so that it highlights etc), you can do this by clicking the cursor onto a different view (eg plan view) and then you should be able to click on individual sectoin lines in the surface slicer view.  Apologies if this is not what you were meaning - I found this by accident, but do this regularly.
    Stevie McCafferty
  • 8.  RE: Surface Slicer View
    Posted 30 days ago
    Good suggestion. I am trying to select in the slicer view. It turns out that the plane manager and cutting plane tool is working ok for what I am doing. Thanks!
    Zach Edwards
