We are struggling with sync on only one of 10 identical devices where the synch will start, but has the 'errors occurred' warning. All are running Nautizx41 handheld devices. Clicking on the error details returns the message "Sync. The Server returned an error: 404." Im assuming that this is a 'not found' error. Since the only difference between the devices is a licensing one, I'm guessing this is a license / config issue?
We have 10 Terraflex licenses of which 9 are using one month licenses (and working fine) but the tenth is a permanent Terraflex Core license and this is the one that wont sync.
We've tried all the usual things: there are no draft forms (and have deleted all forms and projects from the device), restarting the app, the device, logging out and in etc. The device has full wifi connectivity and fast internet - browsing and all other apps work.
Can someone give us a steer?
thank you in advance for taking the time to help.
Charles
Charles Nicholls
