Morning
Recently updated our access to the version 2025.10 on a TSC6
Previously we were able to position our total station using a minimum of 2 GNSS observation, this would bring up the resection results page and have the option to add additional points, change to 1D, 2D etc
Since updating to 2025.10 access now decides which points to use, forcing a minimum of 3 points, sometimes up to 5, will only use 2 of them and can be the points with the worst geometry / residuals.
Ive attached an image from a site team showing 5 points required, from this screen we are unable to change which of the points it uses, even pressing 'use' does not change anything, you cannot change 1D 2D.
Is there any way of changing this to how it used to be, or being able to see the tolerances that access it using to decide which points are used?
Cheers
L
Laurence Washbrook
