Trimble Controller modifying my R2 bluetooth settings
  • 1.  Trimble Controller modifying my R2 bluetooth settings
    Posted 5 days ago
    hey everyone, hopefully someone can help me. We often use a Trimble R2 antenna and sometimes we connect it to a Trimble controller and sometimes to a third party app. When doing this switching, the output gets replaced and it does not longer publish NMEA packets like we wish. Is there a way to change this back to NMEA by bluetooth? I've seen that you can only do this via WiFi in the WebUI, but this is not very helpful because the webui is not mobile friendly and its not possible to set this by the field workers from their phone.
    What alternatives do i have?
    Ideally it would be to have an app to set this back to NMEA or otherwise something to understand the default packages sent by whatever the controller defaults the antenna. Any help is very much appreciate it
    Thanks in advanced
    Gaston Lifschitz
  • 2.  RE: Trimble Controller modifying my R2 bluetooth settings
    Posted 4 days ago
    Edited by Norman Smart 4 days ago
    According to page 38 of the R2 User Guide, you can reset the R2 to factory  settings by pressing the power button for 15 seconds, until the LED changes to a slow yellow flash - I'd expect that to reset the NMEA output, but I don't have one available to try.  Have you tried that method?  Be aware that doing a factory reset might clear Bluetooth pairing as well.
    (EDIT:  Nope, a 15-second reset to defaults won't work.  Page 38 of the manual says that NMEA defaults to OFF on all ports in the default settings.)
    (Second edit:  I found an R2 and tried the Factory Reset (press and hold the power button until you see an orange flash, took about 18 seconds for me.)  On my receiver, doing the factory reset DOES reset the R2 so it gives NMEA on Bluetooth 1.  So there's a strong possibility that the User Guide is wrong, and a Factory Reset will allow you to use NMEA-based software.
    Norman Smart
  • 3.  RE: Trimble Controller modifying my R2 bluetooth settings
    Posted 4 days ago
    Edited by Mark Kellaway 3 days ago
    Hi Gaston,
    On the R2 when you connect to it with an app that talks to it directly, like TMM for example, it results in the NMEA output being disabled as you have noticed. The best way to handle this is to create a "START_UP" receiver config. That way, a receiver restart automatically applies the required settings.
    (EDIT)
    The name of the config in m y previous message was incorrect, some more detailed steps if the suggestions from Norman and Ryan aren't sufficient:
    • Set up the receiver as required in the WebUI
    • Use Receiver Config / Application files to download the current application file, and rename it to 'Power_up.cfg'
    • Upload the Power_up.cfg file to the receiver
    Best regards,
    Mark Kellaway
  • 4.  RE: Trimble Controller modifying my R2 bluetooth settings
    Posted 3 days ago
    Hi Gaston,  one can also maintain NMEA messages upon disconnect by checking this check box in the R2s WebUI under I/O Configuration / Bluetooth / NMEA:
    Ryan Scott
