Note: Don't worry about baud rate / data rate settings - these don't matter with a Bluetooth connection
Sent: 07-28-2025 16:42
Subject: Trimble Geo 7X - Bluetooth COM not working, connect button dimmed out
Ahh, ok. I will try with my laptop again but it did not work the last time and that is windows.
How does the GPS know anything about what host system the connected bluetooth device uses? The Bluetooth serial port is native and should not be affected by underlaying OS, but I trust your knowledge.
I will try with my laptop tomorrow and confirm that that works.
Cheers
Emil Andersson
Sent: 07-28-2025 16:38
It's not purely about Android, the problem is the combination of Geo 7x and Android.
Geo 7x was not designed to allow connections to Android, so you you can Bluetooth pair a Geo 7x to an Android device but there's no way that the Android device can get GNSS data. With Windows, you can pair the Geo 7x with a Windows device then the GNSS Connector app lets you output data from the Geo 7x in a way which works with Windows.
Norman Smart
Sent: 07-28-2025 16:24
Hi Norman, thanks for your answer!
This has nothing to do with android, it is the bluetooth option to "connect" to a device that does not work. It is possible to pair the GPS with different devices as I mentioned but when I want to make the connection (bluetooth) active, the "connect" button is disabled.
Best Regards
Emil
Emil Andersson
Sent: 07-21-2025 14:48
I don't think that the Geo 7x can output GNSS information to Android devices - at the time the Geo 7x was designed, Trimble really didn't support Android devices. Here's a Knowledge Base article from Frontier Precision (a large MGIS dealer) which supports this statement.
Working from memory since I don't have a Geo 7x available at the moment, there was a free Trimble app (GNSS Connector) which let you output NMEA to a Bluetooth serial port and you could connect to that serial port using a Windows PC or Windows embedded (WEHH) device. I found a Geo 7x manual here on the NEI site, but I'm not sure where you'd find an installer for Trimble GNSS Connector for the Geo 7x.
Norman Smart
Sent: 07-16-2025 16:14
Hi, we have an older Trimble geo 7x system we want to use with another platform just as an GNSS GPS.
I can add my phone, tablet and PC as a bluetooth device on it but i CAN NOT connect. that button is always dimmed out. What can be the problem?
Also, I can not see any "services" under any of the added bluetooth devices BUT the devices show up under the option to output NMEA in another menu.
Best Regads
Emil
Emil Andersson
