Trimble Mapping & GIS Software support for the Trimble receivers supporting TIP
  • 1.  Trimble Mapping & GIS Software support for the Trimble receivers supporting TIP
    Posted 01-20-2022 09:02
    Edited by Mark Kellaway 06-15-2025 15:24
    [Edit 16 Jun '25 - Mark Kellaway]
    As it stands today, below is the level of support offered by Trimble Geospatial and Esri field software relevant to our Mapping and GIS customers.
    Trimble Access: Full support for ProPoint engine & TIP tilt compensation
    Trimble Terraflex: Supports ProPoint & TIP tilt compensation (calibration and pole bias adjustment with TMM)
    Esri's Field Maps (via TMM integration): Supports ProPoint & TIP tilt compensation if used with mock locations via TMM on Android. On iOS Supports connection to the receiver and can consume ProPoint positions, TIP tilt compensation is NOT supported
    Trimble Penmap for Android:  Supports ProPoint & TIP tilt compensation (calibration and pole bias adjustment with TMM)
  • 2.  RE: Trimble Mapping & GIS Software support for the Trimble receivers supporting TIP
    Posted 01-20-2022 09:59
    Thanks Lane - can this aspect about TIP be added into the R12I row (via the popup boxes) in the Product Configuration Guide?
    Fully Compatible as it says in several boxes now - might make some folks think that means TIP, too.
    Gale Shea, GISP
    MGIS Rep, WI
  • 3.  RE: Trimble Mapping & GIS Software support for the Trimble receivers supporting TIP
    Posted 01-20-2022 11:26
    Hi Gale,
    We are actively working on updates to the Product Configuration Guide and hope to include additional, useful information (such as TIP support) when those updates are completed. Thank you for bringing that up!
    Lane Carter
  • 4.  RE: Trimble Mapping & GIS Software support for the Trimble receivers supporting TIP
    Posted 06-13-2025 16:09
    All,
    just circling back on this old forum. Tilt compensation was added in TeraFlex about a year ago.
    Zach Edwards
  • 5.  RE: Trimble Mapping & GIS Software support for the Trimble receivers supporting TIP
    Posted 06-15-2025 15:25
    Thanks Zach, original post updated, let me know if you spot any errors!
    Mark.
    Mark Kellaway
