Jamie, this should all be resolved in the latest version of Field Maps. It should no longer require you to browse to the Mobile Manager folder. Make sure Mobile Manager and Field Maps are on the latest.
Zach Edwards
Sent: 07-31-2025 08:10
Subject: Trimble Mobile Manager Folder, ArcGIS Field Maps, and Shared iOS Devices
Why can't they access app folders? We also utilize shared iPads and have no problem. Ours are managed by our IT department using Microsoft InTune. If yours are also managed through a platform, maybe a setting in the management platform could be adjusted?
Jamie Maxwell
Sent: 07-30-2025 09:16
Hello everyone,
Recently our organization has moved to Shared iPads (iPadOS 18.5) since they move between teams quite a bit. However, individuals are no longer able to access app folders - such as the Trimble Mobile Manager folder when adding a location provider in ArcGIS Field Maps.
Is there a workaround for having to browse to the Trimble Mobile Manager folder? Is there a plan to remove the requirement to browse to the folder in the future? As it stands now, we cannot use any of our Bluetooth receivers using Trimble Mobile Manager for connection and configuration.
Thanks,
Noah Williams
