Tip of the Week #12 - Creating Orthorectified Image for Facade Reconstruction - Using Multiple Stations
By Boris Skopljak posted 05-31-2017 05:50
Do your projects require facade or vertical surface reconstruction or modeling? If so, then you might find this tip useful to you.
In some projects, it’s impossible to find THE one setup where you can see the whole object without masks (between the instrument and the object you might collect in your photo: people, cars, trees, light poles etc…)or because the object is very long (building in a narrow street etc…)so you need to make multiple setups in order to always be in front of it with a good angle.
One way could be to create several “rectified images” but you might create several planes and so the assembly of these several created rectified images will not be optimal.
In the example below we can see that station 6 provides a good view of the object but some of the areas on the right and left are obscured by trees.
On the other hand, station 4 presents a clean bottom left area but a light pole on the right area (which is not good for our purpose).
Images from Station 3 also present a nice perspective but contain a light pole in the middle.
What we suggest now is to use Station 6 as the base of the rectified image (perfectly in front of the building) to create the “Plane” and then use the 2 other stations to fill the missing parts by simply picking in the Plane the areas that couldn’t be selected previously. We will then obtain 3 rectified images in the same plane that we can then export to a 3rd party Software (AutoCAD, Sketchup, etc…) or in order to generate drawings or directly in TBC.
Note: if you know your goal is to create accurate orthorectified images, it’s very important that you do a very good traverse (use correct prisms etc…): this will minimize the overlapping difference between stations. As well, use the same image resolution and try to have your stations as equidistant as possible to the object
In Point Clouds tab > Imagery: Open the “Create Orthorectified Image” ” tool and define a “New Plane Definition”
We would like to suggest that you use the “Vertical Plane” method in a similar project as shown in the image (also make sure that you have points displayed in order to pick the position of the plane). Note also that it could be a good idea to name your plane (useful if you do an area that requires multiple plane creation as well as the Image).
Now pick the 2 corners for the creation of the image (do not select area with masks….) and define the resolution and select Create.
Note: you can check the results in 3D View by hiding everything except the Georeferenced Image (as shown in the view of the newly created Rectified Image below.
Now Back in Station View, select the next station you want to use to complete the building façade.
CAUTION: Be careful that despite you changed the Station view from Station 6  to Station 4, the active station in the “Created Orthorectified Image tool” is still Station 6 (as we didn’t close the tool) so please make sure to change the Station there to Station 4 to avoid issues.
It is very important that you use the same Plane Definition than before and simply pick 2 new points to define a new area (select area that wasn’t covered in the previous step) and select Create.
Repeat the Steps for the next Station that will help you to fill the blanks. Check the result of your 3 rectified Images together as shown in the image below. Note that it could be good to equalize the photo in TBC or in the field.
We hope this tip will be useful and make you successful when creating orthophotos within TBC.
Credit this week goes to our Application Engineer, Arnaud Lezennec. Thanks Arnaud!
Happy Surveying,
TBC Team
6 comments
12-10-2019 00:51
Hi Sudam
Thanks for your response!
I use "Orthorectified image" comand.
I read one more time carefully Tip#12 and find the choosing create, TBC
will create a ortho picture: "We will then obtain 3 rectified images in
Sketchup  etc…) or in order to generate drawings or directly in TBC."
Ok, then everything is correct, but any way, can you give some
recommendations, how to merge these created orthos in one picture?
One more thing I found. After creation of two orthos I found that
pictures do not match with each other even they are created on the one
common vertical plane. Please see attachment.
BR
Edgars
12-09-2019 08:16
Hi Edgar,
Are you using the 'Orthophoto' command or the 'Orthorectified image' command ?
Regardless, I was not able to reproduce this issue. Could you explain the steps you took to create the rectified image ?
Thank you,
Sudam Fernando
12-06-2019 06:31
Always as I choose OK, the program makes a new orthophoto. As a result, I get not one orthophoto but several, each from each station!!!
What am I doing wrong?
I use TBC 5.2
04-25-2018 20:21
Very useful~
06-04-2017 23:54
Great Work. I was wanting to know how this worked. It would be good to have this data so other people could play with it. Also is there a way to take this picture and then coordinate all the windows from the image?
05-31-2017 14:29
Maybe this needs to be added to the help files within TBC? or tutorial
