Importable Data Formats
Exportable/Uploadable Data Formats
File Format
Description
File Format
Description
.06o
RINEX (GPS base files)
.12dxml
12d files
.12da, 12dxml
12D files
.avoid.svl
Avoidance zone files for GCS machines
.ali
ISPOL horizontal alignment files
.asc
ASCII, point, Nikon NEH, Nikon TS, TDEF files (see note on TDEF files below)
.alz
CLIP vertical alignment files
.avc
Avoidance Zone files containing 3D geographic coordinates (and photos with .avz)
.apd
tunnel shapes
.bmp, .gif, .jpg,
.png, .tif
image/background map files
.asc
ASCII, TDEF, raw data files, InRoads horizontal and vertical alignment files
.cal
Site Calibration files
.avoid.svl
SiteVision avoidance zone files
.cdg
.bmp, .jpg, .png, .tif
Image files
.cpz
Control point files containing 3D geographic coordinates (and photos with .cpz)
.cal
Calibration files
.crd, .inf, .sys
Coordinate file and coordinate system definition files for Fast Survey; Road files
.cfg
Coordinate system configuration files
.csd
Coordinate System database file
.cor
GPS Pathfinder Office files
.csv, .txt
ASCII text, point, trajectory files; event data; NGS data sheets; pipeline attributes; feature attributes, Mobile Mapping, feature definition files
.crd, .mos, .txt
GENIO files
FAST Survey files
.dbf
Esri Shapefiles
.csv
(custom import)
ASCII text, point files, station, offset, elevation files, feature definitions files
.dc
Trimble data collector files; Road files
.dat
GNSS files, DiNi level files, STAR*NET level files
.ddf
Data dictionary files
.dc
.dgf
.ddd
Ashtech ATOM files (G-files), B-files, and Quark files (Q-files) (ddd is the day of the year)
.dsz
Design files containing 3D geographic coordinates (and photos with .dsz)
.dgn
MicroStation design files (also see .i-model (.icm.dgn).dgn below)
.dxf, .dwg
CAD files
.dsp, .persist
GCS display files
.e57
Point cloud files
.dxf, .dwg
CAD files
.emjson
senseFly Mission files
.ds, .htm
NGS data sheet files
.exl
Export Feature Extraction Attribute Map files
.e57
Point cloud files
.fal, .fcl
Feature files
.ecw
Enhanced Compression Wavelet image files
.fxl
Feature definition files
.eje
MDT horizontal alignment files
.ggf
Geoid files
.exl
.gvx
GNSS Vector Exchange files
.fls
Faro point cloud files
.ifc
Industrial Foundation Class files
.fxl
.icm.dgn
Bentley i-model (.icm.dgn) files
.gcj
SCS work order results files
.ilj
TDS Interlock files
.gdb
Esri File Geodatabases
.ini
Site settings; antenna files
.gen
NovaPoint files
Note: The .gen NovaPoint format is supported only on 64-bit systems and in the 64-bit version of Trimble Business Center.
.job
TDS Survey Pro; Trimble Digital Fieldbook; GNSS files; Spectra Geospatial Origin
.geo, .gt, .kof, .llc, .lin, .lmd, .nyl, .prf, .pxy, .sec, .skv, .sos, .tit, .vgp
Nordic software data exchange files
.jpg
Station Panorama Image files
.hpt
HYDROpro™ files
.jxl
JobXML files
.i-model (.icm.dgn)
.kml, .kmz
Earth browser (Keyhole Markup Language (KML)) files containing 3D geographic coordinates (and photos with.kmz)
.ifc
Industry Foundation Class files
.kof
NovaPoint coordinate and observation files
.ilj
TDS Interlock job files
.labelstyle
Label Style files
.inf
FAST Survey files
.las
Point cloud files
.ini
Site settings files
.nod
Somero surface files
.job
GNSS Job files
.pdf
3D PDF files (create)
.jxl
JobXML files (can include SX scan data from Siteworks)
.pdt. .tzp, .ptz
Penmap Project and Template files
.kml/.kmz
Google Earth files
.pod
Bentley Pointools files
.l
Spectra Geospatial Focus DL-15 level data files
.prj
Esri Shapefiles
.labelstyle
Label Style files
.pro
Terramodel project files
.las/.laz
Point cloud files
.profile
Hydraulic excavator profile files
.mch
GCS measure up files
.pts
ASCII point files; Point cloud files
.nod
.rcp
Autodesk ReCap files
.pav
Paving run files
.rxl
Road files;
.pbj
Rangefinder laser files
.sdms
SDMS files
.pdf
Portable document files
.shp, .shx
Esri Shapefiles
.pdt
Penmap project files
.skp
SketchUp files
.persist
PCS Display Configuration files
.smz
Site map files containing 3D geographic coordinates (and photos with .smz)
.plt
CLIP horizontal alignment files
.sos
SOSI vector data files
.pro
Terramodel project files (You must select the SCS Field Data option during installation to be able to import .pro files.)
.spj
Work order files for WorksManager
.pts
(custom import)
ASCII point, DTM files, Point cloud files
.survey
Trimble Survey Pro (version 5.0 and 5.1)
.ptx
Point cloud files
.svd
Job site design files for GCS machines
.ras
ISPOL vertical alignment files, MDT vertical alignment files
.svl
Site map files for GCS machines
.raw
TDS, Nikon raw data files
.tdx
Trimble TBC/RealWorks Scan Data Exchange files
.reb, .*
(.021, .040, .066, .66)
REB roadway and/or surface files
.tif
Orthoimage files
.rxl
RoadXML files
.tmf
TL-Pro Terrain Manager files for Trimble TL-Pro Design Studio
.sce/.sc1
ISPOL alignment cross-section files
.trb
TrimBim files
.shp
Esri Shapefiles (.shp)
TMX (folder)
TMX files
.skp
SketchUp files
.tsd
Planar surface files
.soe
InRoads alignment cross-section files
.ttm
Trimble surface files
.sos
.txt
SCS work order report and record files
.sp3, .sp3c
Precise ephemeris files
.vcl
Project link files; Drill Plan files; Pile Plan files; Site mass haul files
.spj
SCS work order results files (can include SX scan data and images from Siteworks)
.xml
LandXML files; SCS900 Tunnel files; Geodatabase files; TILOS files; Inframodel files; pile plan files; UASMaster files, Mobile Mapping files; ADAC files
.survey
Trimble Survey Pro (version 5.0 or later) files
.svd
SiteVision design files
.svl
SiteVision linework files
.sys
FAST Survey files
.tdx
.tos, .toi
Trimble X12 Laser Scanning files
.tra
MDT alignment cross-section files
.trb
TrimBim files
.trv
CLIP alignment cross-section files
.tsd
.tsf
Trimble scanner files
.ttm
.tzf
Trimble point cloud files
.t00/.t01/.t02
GNSS data files
.txt
SCS work order results files, CARTOMAP files; CAiCE files
.vcl
Project link files
.xml
LandXML files; Inframodel files; NGS OPUS files IREDES tunnel and drill plan files; piling results files; 12d files; ADAC files, LINZ cadastral survey files
.xsr
GEOPAK XS-List Report (cross-section) files
.xyz
Point cloud files
.yxz
Wirth YXZ files, Point cloud files
