Tip #139: Time-Dependent Transformation Enhancement in TBC v5.40
By Erin Johnson posted 02-12-2021 16:21
Good morning TBC’ers! The time-dependent coordinate transformation feature in TBC, which is used to transform between ITRF 2014 at the epoch of measurement and the global reference frame, has been enhanced to use displacement models in the working area when available in TBC v5.40.
A displacement model is a model of the movement of points on the surface of the Earth due to plate motion, tectonic strain accumulation, seismic/ post-seismic deformation, glacial isostatic adjustment, and/ or other geological or anthropogenic processes that cause significant coordinate changes over large areas. The model is used to propagate coordinates from one epoch (such as the epoch of measurement) to another (such as the reference epoch of the selected global reference datum). This ensures users obtain optimal accuracy in coordinate transformations and the best possible coordinates in the selected coordinate system.
The following table shows the current list of reference frames in which TBC and Trimble Access will be able to convert RTX positions with centimeter accuracy:
Country
Reference Frame
Displacement Model
Australia
GDA2020
None
Brazil
SIRGAS200
VEMOOS2009 2019-12-01
Canada
NAD83(CSRS)v7
CSRS Velocity Grid V7.0
Denmark
EUREF-DK94
NKG-RF03
Estonia
EST97
NKG-RF03
Finland
EUREF-FIN
NKG-RF03
France
RGF93v2
None
Germany
ETRS89-DR91(R16)
None
Iceland
ISN2016
ISN2016 2019-07-01
New Zealand
NZGD2000
NZGD2000 Deformation Model
Norway
EUREF89
NKG-RF03
Russia
PZ-90.11
None
Sweden
SWEREF99
NKG-RF03
UK
OSNetv2009
None
USA
NAD83(2011)
HTDP V3.2.9
The Project Settings dialog has been updated to include two new read-only fields in the Coordinate System Summary section: Global reference datum (the reference frame for global coordinates) and Global reference epoch (the reference epoch for global coordinates).
Note: Advanced users can check, or even update, time-dependent transformation parameters in the TimeDependentTransformationDatabase.xml file located in C:\ProgramData\Trimble\Geodata.
I hope this tip gives you a greater depth of some of the new enhancements included in TBC v5.40-- have a great weekend!
0 comments
