Tip #164 - Create a Surface from a Reference File
By Hannah Poon posted 11-26-2021 10:36
Hey TBC’ers! Happy belated American Thanksgiving! Have you ever wanted to create a surface from a reference file? Utilizing the new Create Surface from Reference File command, you can create a new reference surface based on the linked reference surface that is selectable and can be used to create surface-related CAD objects (e.g., surface contour lines). The resulting CAD objects display and are editable in your project even if the reference data is hidden or removed. This great, new feature was introduced in Trimble Business Center v5.60
Follow the steps below to learn how to create a surface from a reference file.
  • To create a new reference surface from a linked reference file that is selectable and can be used to create surface-related CAD objects, navigate to Surfaces and select Reference Surface to display the Create Surface From Reference File command pane.
  • In the Create Surface From Reference File command pane, you can enter a name for the new reference surface, select the linked reference VCE project file, and select the linked reference surface on which you want to base the new surface. Then, click Apply.
  • The new reference surface is created and a new Reference File Surface node is displayed in the Project Explorer (Surfaces > New Surface). Right-click New Surface (the new reference surface) and click Create Contours
  • You can choose your contour interval, color, contour line weight, distance between labels, and more. Then click OK to see the surface contour lines
Here, the new contour lines are displayed in Cyan, with a contour interval of 1.000, contour line weight of 1.00 mm, and distance between labels of 16.823.
  • In the View Filter Manager, you can turn off the reference file to better visualize the new surface. The resulting CAD objects display and are editable in your project even if the reference data is hidden or removed.
Looking for more in-depth instructions? Press F1 at any time when using TBC to open the Trimble Business Center Help window to view step-by-step instructions, workflow strategies, and detailed descriptions related to the task you are performing. Or perform a simple search to find out more about any TBC topic.
To download TBC v5.60, you can head to https://trimble.com/downloadTBC. To learn what’s new in our latest release, you can visit https://geospatial.trimble.com/blog/whats-new-tbc-v560.
I hope this tip comes in handy in one of your upcoming Field to Finish Workflows!
#trimblegeospatial
#tbc
#referencefile
0 comments
