Hey TBC’ers! Before using imported GNSS data in a project, you can verify the raw data and correct field errors in the Receiver Raw Data Check In dialog, which displays during import. For example, on the Antenna tab, you can verify that the antenna data is correct to ensure the highest accuracy for your baselines and make edits as necessary. This week’s tip shows you how to set the value of several cells (e.g., antenna height) to the same value in the Receiver Raw Data Check In dialog.
Follow the steps below to learn how to set the value of several cells to the same value.
- Make sure that one of the cells is set to the value you want to use for the others. If not, click in the cell and correct the value.
- Press [Ctrl] and click the first column of each row you want to edit. The selected rows will be highlighted.
- Position the cursor over the cell containing the correct height, and right-click. A context menu displays two choices (as shown below):
- Use <value> for all points.
- Use <value> for selected points. (We will select this option for this example.)
- Select the correct value. The value in the selected rows updates.
To download the latest version of TBC, you can head to https://trimble.com/downloadTBC
