Tip # 86 : Creating different viewpoint using the ‘Defined Views’ command
By Sudam Fernando posted 09-06-2019 14:14
Tired of always having to rotate your views to a specific spot to QA your data or want to share a specific perspective of your data to others ? Well using today’s tip, you can do exactly that !
The command ‘Defined Views’ can be used in both Plan view and 3D view to easily define views that we want to view later.
To access this command, we must first go to the Support Ribbon and select ‘Defined Views’ and the ‘Defined views’ command will open as shown below
Then we must simply have the view want to be defined in either 3D or Plan View and select the thumbnail in the command. Then we must name the view as shown below
We can have multiple defined views in both 3D and Plan view and delete them by selecting the thumbnail of the view and clicking the garbage can icon on the far right.
For each of the defined view TBC creates a view filter and we are able to select using the filter list :
Hope this tip comes in handy, the next time you are using Trimble Business Center !
0 comments
