Tip # 91 : Help getting started with major workflows instructions
By Sudam Fernando posted 11-01-2019 14:42
Getting familiar with a new workflow in TBC can be daunting but we as we all know, we have the TBC tutorials that can help us get off the ground using the provided data sets. Now, after we are familiar with the tutorial data set and we want to use our own data sets, what do we do ? Well we could follow the workflow described in the tutorial or we can use the instructions for workflows in the Help document !
The major workflows instructions are an additional method of getting familiar with the workflows within TBC. These instructions walk you through some of the major workflows within TBC with the links to commands straight within the help document. Lets say, I finished the tutorial for ‘Performing a network adjustment’ and I would like to perform a network adjustment of my own survey data.
First you would have to go to the ‘Support’ ribbon and select the ‘Help’ button or simply hit ‘F1’ on your keyboard to open the command.
If you aren't already, navigate to the ‘Welcome to Trimble Business Center Help’ page and here you will see the workflows with the fast track instructions. I will go ahead and select the ‘Adjust Network’ workflow
and here, I am given the reason behind network adjustment along with the steps to reproduce this workflow. selecting the commands on the right side will also open that command in your TBC project.
Along with the tutorials and these fast track workflows, hope you can get started on different workflows TBC has to offer !
0 comments
