Tip #199 - Run Last Command [TBC Optimization]
By Vyom Kaushik posted 04-17-2023 10:25
Hello TBC’ers!
Have you ever wanted to run the last command you used to save time looking for it? Look no further with the
Run Last Command command to quickly run the same command multiple times in a row.
Follow the steps below to learn how to run a previous command.
1) For quick access, add the Run Last Command command to the Ribbon and/or Quick Access Toolbar. Click the arrow at the end of the Quick Access Toolbar and select “More Commands” from the dropdown menu to open the Options dialog.
2) In the Quick Access Toolbar tab, scroll through the list of commands until you find Run Last Command. Select it and click the Move button located between the two lists.
3)
The Run Last Command icon now displays in the Quick Access Toolbar. Click on it to open up the last command you used.
4) Run Last Command pop-up will now appear within your TBC workspace. You will see the last TBC command which you ran as part of your workflow.
Example: I used the Measure Command, therefore this menu option appeared when using Run Last Command.
To download the latest version of TBC, you can head to https://trimble.com/downloadTBC
Complete free self-paced workflow-based courses with hands-on guided software experiences on Learn.Trimblehttps://learn.trimble.com/pages/422/trimble-business-center-tbc
For additional learning content, visit our TBC Survey and Construction YouTube page:
0 comments
