Question about TSC7/Trimble Access.
When I'm in measure codes and double code a feature on one shot, it wants to continue adding the additional code on each shot after. I usually don't catch it until several shots afterwards because it didn't do this with the TSC3. Does anyone know a setting to prevent this? I haven't had time to figure it out and was hoping someone else here had the same issue and can tell me the solution so I don't have to figure it out.
I noticed that if I hit escape once and remeasure the second code goes away, but that's not really a solution because I don't catch it every time. With the TSC3 I could shoot a site with only occasionally glancing at the screen to check something once I got on a roll with my codes menu set up.------------------------------
Jon Moeller
