As it stands today, below is the level of support offered by Trimble Geospatial and Esri field software relevant to our Mapping and GIS customers.
Trimble Access: Full support for R12i ProPoint engine & TIP
tilt compensationTrimble Penmap for Android: Supports the R12i ProPoint & TIP tilt compensation (offers integrated pole bias adjustment with TMM)
Trimble Terraflex: Supports connection to the R12i and can consume ProPoint position. TIP tilt compensation is NOT supported
Esri's Field Maps (via TMM integration): Supports connection to the R12i and can consume ProPoint position. TIP tilt compensation is NOT supported
In order to support R12i TIP tilt compensation in TerraFlex or Esri's Field Maps, changes are required in the TPSDK implementation for both software packages. This work is being discussed internally.
Lane Carter
