Hi Geri
We have managed to reproduce the problem, but the only method we have found to do this involves (1) attach the R1 to your PC using a USB cable then (2) run the firmware updater, which should display the R1 in the list of available devices, then (3) turn on the R1 (could also do this before step 1 or 2), then (4) connect an application on your PC to the USB serial port, then (5) click "Next" in the updater to start the update process - the "failed to get device configuration" message appears.
To avoid getting the message, we recommend that you close any applications which may connect to the USB serial port before you run the firmware updater, and you ensure that the R1 is turned off before attaching it to the USB cable.
Norman Smart
Sent: 07-01-2021 16:55
Subject: R1 Firmware Update
I received the following error message when attempting to update firmware utilizing Trimble 99133 Series FW Upgrader_5.47.msi:
trimble 1R firmware update failed to get device configuration
Anyone with knowledge, please respond.
Geri
Geraldine Bruggink
