Use this function to analyze the Water and Sewer project for crossing pipes and pipes, which is falling short of the minimum spacing (specified by users).
You find the function in the following location:
The following method is used:
The function will draw all the crossing pipes in the longitudinal profile. Annotation for the pipe, station, and elevation will also be drawn.On the same longitudinal profile, collision analysis can be executed for any number of trenches one after the other to obtain all the crossing pipes.
