Novapoint
NOVAPOINT 2020.FP1 Release Notes
01-03-2021 19:12
NOVAPOINT 2020.FP1
Release date: 09.10.2020
QUADRI FOR WINDOWS (FORMERLY NOVAPOINT BASE)
Quadri for Windows is replacing the legacy product Novapoint Base as it is known in Novapoint 19 - Novapoint 21.
For release notes related to Quadri for Windows go here.
NOVAPOINT CAD TOOLS
NEW: Support for AutoCAD 2021 products
NOVAPOINT ROAD
General
ENHANCEMENT: Dialogs have been improved to handle 4K display resolution and scaling in Windows.
FIXED: Quadri Import of roadmodel files could produce linetasks without geometry. This could stop/crash the share process to the Quadri Server.
FIXED: Quadri Import of roadmodel files could place the linetasks and terrain sections inside other folders or imports. Now they are located on the same level in the Process Tree as the import itself.
Calculations and Dialogs
ENHANCEMENT: Better logic to connect the correct alignments as surface edge if the GUID fails or is not correct.
ENHANCEMENT: Some roadmodel gets corrupted after a crash. New method for handling the DMI-file to avoid it being corrupt in the future and to avoid sharing a corrupt DMI to the server.
ENHANCEMENT: Cut features are now produced with numbers in featurename that correspond with the materialtypenumber (1-25) that are used on the subsurface task.
ENHANCEMENT: Removed 1mm-surfaces outside the road surface boundary.
Example: Set a boundary on the right side to the shoulder surface. You would still see 1mm-surfaces for ditch, rockcut, soilcut etc.
ENHANCEMENT: When building the roadmodel we are now purging the list of alignment used in the model so that they do not clutter the model when sending to 3rd Party software.
FIXED: 3D results could disappear when a model ended in a bridge/tunnel and the model calculated twice because of dynamic alignments.
FIXED: Alignment as surface edge was not followed correctly when the road alignment was in an exact east-west direction.
FIXED: Rockcut could end up as soilcut when there was a mix of overlapping subsurfaces to consider.
FIXED: Issues with interpreting subsurface layers interpolation where many surfaces overlap eachother.
FIXED: Errorcode 101 due to selfoverlapping pavement layers did not produce any results to Quadri for the roadmodel.
FIXED: Roadmodel could crash in some circumstances.
FIXED: Slope method 0 inside detailed pavement did not always work when used in the pavement layers.
FIXED: Upgrade from NP20 to NP21 did not set the correct median radio-button for Base course 3 and Sub-base course 3.
FIXED: Cases where selecting a specific alignment as surface edge didn't work in the Road Surface description.
FIXED: Issues or crash in roadmodel building and Sight Analysis because of error in rounding of start/end chainage on the road task to closest 1mm could fail in some circumstances.
FIXED: Sight Distance Analysis failed in sections where Landscaping was in use.
REMOVED: Columns for “Minimum Width” in the advanced Terrain Boundaries function as it is no longer in use. Search width left/right is enough.
Quantities
ENHANCEMENT/FIXED: There could be some cases where there were a bigger mismatch between the Excel Report and Table View.
ENHANCEMENT: Cases of slow Quantity Reports.
FIXED: Roadtask without an alignment (ex. roadtask created directly from received DMI/DMR) would crash. Now it produces a report, but only the summary report.
FIXED: Units in Summary sheet for Rock < 1m said m2 for all the values, while some are actually m3. Units are now properly listed for each row.
Cross-section Viewer
ENHANCEMENT: Selecting any illustration object will show what task it is related to in the dialog.
ENHANCEMENT: Innerslope surface was filtered away when overlapping with f.ex. the fillslope roadsurface.
FIXED: The Viewer could crash when jumping back and forth between cross-sections.
FIXED: Naming of the closed ditches could be switched. Also sorted so that the naming better correspond with what we find in the dialogs for Closed Ditch and the Settings.
FIXED: Cleanup of the pavement layers could be wrong and confuse the user. NOTE: The 3D results in Quadri has always been correct regardless of this.
Alignment Design
ENHANCEMENT: Improved the vertical window by removing the noise caused by linestrings in crossing roads or other tasks.
ENHANCEMENT: Partially fixed fixation has been placed in the middle of the element since NP21.FP4 to avoid errors when changing fixation logics.
It has turned out to be an irritation and we have now changed it back, but improved it. Also set the old style as default.
Users can switch between the two methods in the Alignment Design Options dialog.
FIXED: Picking a line and arc that has offset in CAD will apply a clothoid between them instead of a straight line.
FIXED: Terrainsetup based on rehabilitation function in road pavement was slow.
FIXED: Pressing SaveOnly+SaveOnly+Cancel would lead to corrupt vertical alignment data.
FIXED: Alignment Design could state that a geometry was NOT OK even when it was OK.
FIXED: “CB not OK” could be stated in the dialog even when calculation basis was OK for the Linetask.
FIXED: Pressing ESC while in a Skype videochat could terminate the chat session.
Draw to CAD
ENHANCEMENT: Draw Road model - Contourlines now have the option to select specific surfaces to draw contourlines on.
ENHANCEMENT: Draw Cross-sections also draws the section frames for better understanding of why the roadmodel section is suddenly cut.
(By default the layers in CAD are set to frozen and no-plot)
FIXED: Draw Horizontal Geometry dialog crashed when using User-Defined styles.
FIXED: Draw Road model - Elevation Annotations did not remember number of decimals when updating with NCO in the drawing.
FIXED: Draw Road model - Property Boundaries could be a zigzag line in curves when using roundings in the cross-section calculations.
REMOVED: Draw Road model - Pavement thickness option is removed as it caused some issues and because it no longer has data to draw.
FIXED: Draw Cross-sections did not draw mass hatches on all selected cross-sections.
FIXED: Draw Cross-sections with Design objects or illustration objects that gets clipped by the “frame” would dissappear. Now they are not clipped at all instead.
FIXED: Draw Cross-sections to PDF could crash in some circumstances.
FIXED: Draw Cross-sections did not correctly position the roadmodel in some circumstances.
FIXED: Draw Terrain Cross-sections - Could not to press Draw after changing drawing style configuration.
FIXED: Drawing Style Configuration - Could not select to draw based on NP21+ surfacenumbering (ex. 1.01). Only old numbering was available (1.1). Now all should be fixed.
NovaRehab
ENHANCEMENT: Point code and point name are visible in views.
ENHANCEMENT: Import of Cogo point LandXML files
ENHANCEMENT: Import and Export of LandXML Alignment
Norwegian market
ENHANCEMENT/FIXED: Using non-rounded values for sight analysis for Norway 2018 - H3 - 110km/t. Rounded values gives 230m sight distance, non-rounded values gives 227m sight distance.
Finnish market
ENHANCEMENT: Draw Roadmodel Surface Edges: The column for “Pick” (FIN: Käytä) was too narrow hindering the use of the drop-down menu.
FIXED: Draw Longitudinal Profile with Finland.RS it did not show pavement info.
Swedish market
ENHANCEMENT: New Swedish styles with layer names from SB11 in Draw cross sections and Draw Long profile
NOVAPOINT RAILWAY
In addition to the relevant changes to Novapoint Road, these are release notes specific for Novapoint Railway.
NovaTrack
NOVAPOINT WATER AND SEWER
In general
Quadri - IFC export
NEW: Possible to separate pipeline in two objects: RefLine and Solid
NEW: Support for User Defined PropertySet
Construction
IMPROVED: Removed 24 characters limitation for Trench name in design
Cross Section calculation
  • In general improved stability
  • Improved behavior regarding interpretation of Cut in Fill
  • Generate solid for Trench protection layer even if thickness is less than specified in the configuration
  • New setting for removing pipe volume from trench layer solid (default Off)
International version
Configuration database
UPDATED: Added new Pipes, Connectors, Materials, Symbols, and Cross sections
Quadri - Presentation
NEW: Drawing rule for plan presentation
NOVAPOINT TUNNEL
FIXED:
NOVAPOINT ROAD SIGN
All Versions
Enhancements
General - The support for 4K resolution is improved (#HAN-2815)
Finnish Version
New
The program has been updated with support for a number of the new signs launched by the Finnish Road Administration 01.06.2020. The new version of the sign program can for a transitional period run in parallel with the version of the program that supports the previous standard.
Enhancements
TSLINE, Added support for a setting dialogue to controll the function (#HAN-3001)
EPS - Added a option in the dialogue for export geometry as ARC or LINE segments (#HAN-2912)
3DSIGN - Added support for 2-pole combinations for “std. signs” (#HAN-3160)
3DSIGN - Added support for KAPSU equipment (#HAN-3171)
Fixed
General - The size for the TSINFORMATION is not updating when running UpdateSize (#HAN-3085)
CustomSign - Removes the original POLYLINES after creating the sign (#HAN-2992)
Nowegian Version
New
151 - Added support for new sign (#HAN-2825)
650.22 - Added support for new sign (#HAN-2828)
790.16 - Added support for new sign (#HAN-2827)
General - Added support for 650.22 and 790.16 in variable signs (#HAN-2829)
Enhancements
Save Image - Improved support for grey background (#HAN-3150)
Color Field - Added support for grey background (#HAN-3151)
Custom Signs - Grey background (color 253) work same as for other signs (#HAN-3152)
3DSIGN - Added support for more complex user defined foundations under PORTAL (#HAN-3168)
306.3 - New text for description (#HAN-2826)
Fixed
General - It was not possible to modify the value for FILM on signs with “dynamic” sign numbera… e.g. sign 600.xx (#HAN-2830)
General - The list of text in “favourites” was only visible when Sami keyboard is expanded (#HAN-3166)
FONT - The geometry for character “k” was not ok after TSEXPLODE (#HAN-3303)
TSLINE - The program hang on edit reference line when some values was interpreted as the same number (#HAN-2961)
Swedish version
New
E31-x and E32-x - Added support for new sign (#HAN-3003)
Enhancements
Fixed
FONT - The geometry for character “K” is updated (#HAN-3002)
F27 - The program coverted in some cases automatically a . to a , (#HAN-2673)
F34 - The distance text was in some combinations on top of the arrow (#HAN-2941)
NOVAPOINT ROAD MARKING
All Versions
Enhancements
General - The support for 4K resolution is improved (#HAN-2738)
General - Some of the dialogues are extended to display full name (#HAN-3165)
Fixed
Properties - The program now ignore check for , in “Description” (#HAN-2851)
Properties - It was not possible to change properties on “TEXT” objects (#HAN-2858)
Properties - Not all objects “refresh” the list of values if program was updated with new values (#HAN-3223)
Nowegian Version
New
1053 - Added support for new text object (#HAN-2832)
Enhancements
General - The description for linetype 1008 is updated (#HAN-2850)
Properties - Added support for “Håndlagt” as an option for ApplicationMethod (#HAN-3224)
Properties - Added support for “Ingen profilering” as an option for StructuredPavementMarkings (#HAN-3236)
Fixed
RMTABLE - The preview of linetype in the table was not ok for “Varsellinje” ⇐50 Km/h (#HAN-2984)
NOVAPOINT LAND USE PLANNING
Norwegian Version
General
FIXED: Problems exporting plan from AutoCAD to Quadri with multiple Arcs
FIXED: Bestemmelsessoner not connecting
NOVAPOINT PRODUCT LIBRARY
