If there is an error about "Error in client version" during sharing, check the server.xml file: Find the location of a workset by first exiting Quadri for Windows and then editing server.xml in a text editor. The value for "ApplicationName" should be "quadri", not "quadri_20" or anything else.After changing this and saving the file, try again!If this does not help, contact: User support
