How to draw 3D-solids with stakeout data
08-12-2021 06:53
Problem
This is a step-by-step solution to draw 3D-solids and stakeout data.
Solution
Draw 3D solids
  1. Open a new drawing with the correct template
  2. Click on Show 3D Model
  3. Select relevant trenches
  4. A dialogue will appear. Edit in configuration to add parameters to layer and text
  5. Click Create 3D
  6. Double click on the scroll wheel to see the model
Stakeout lines
  1. Click on Draw 3D pipes/ manholes 3D from WS model
  2. Select the correct parameters and reference points and lines
  3. Finish with Draw
  4. Stakeout data can be retrieved from Setting out in the Novapoint ribbon
  5. Click Select object and select the line that represent the trench bottom
  6. Press Enter. Observe the table
  7. Click Draw table and select placement in the model space. Placement will be the upper left corner
