Hi
@Marcin Staszczyk , when I wrote that the "Name" property in Connect is coming from the authoring application, I did not mean that it is directly the value of some specific property in the model file generated by one specific authoring application. Sorry for the imprecise formulation. The Name property is created by Trimble Connect file conversion process using an algorithm that uses various inputs to create a human readable name for the various types of BIM objects in multiple supported input file formats. The inputs for the algorithm vary depending on the file format and cannot be customized by the user. I have verified with the engineering team that the Name property is not customizable in Trimble Connect.
For customizable property sets, I'd recommend using the Property Sets feature of the Workflow Extensions in the browser 3D viewer. In the example below, I have added a new property set called "My Editable Label" and given that to multiple assemblies in Connect:
Please note that the Workflow Extensions / Property Sets feature requires the Business Premium subscription and is currently available in the Connect for Browser application.
Kind regards,
Jari
