How to configure device to allow other apps to use Catalyst
  • 1.  How to configure device to allow other apps to use Catalyst
    Posted 10-14-2018 09:17
    I just purchased the Catalyst antenna and a sub-meter subscription.  Everything works perfectly using Trimble Mobile Manager but I can't get any other app to use the Catalyst GPS location instead of the Android GPS receiver.
    Any assistance would be very much appreciated
    Richard
  • 2.  Re: How to configure device to allow other apps to use Catalyst
    Best Answer
    Posted 10-15-2018 02:44
    Hi Richard
    The Trimble Mobile Manager app lets you share the Catalyst GNSS with 3rd party applications using the 'Share' option In the GNSS settings page.
    The first time you do this requires a small amount of setup which I've detailed below for you.
    Note - This setup is only needed for third-party applications. Trimble Partner apps using Trimble Mobile Manager with the TPSDK (know as Catalyst enabled apps) do not need to use the Mock Locations service to work with Trimble Catalyst. For a list of Catalyst enabled apps take a look at the APPS page here
    Enable Android Developer Options
    You will need to enable developer options on your device before following the steps below. This allows you to choose TMM as the mock location provider.
    • Follow the instructions on the Android developer page - enable developer options and debugging
    • Alternatively refer to your device manufacturer's documentation on how to enable this mode through the device's Settings App
    Enable other apps to use positions from Trimble Mobile Manager
    1. Select the GNSS menu in Trimble Mobile Manager
    2. Select the SETUP option
      Catalyst Share 1
    3. Follow the on screen instructions and select OPEN SETTINGS
      Catalyst Share 2
    4. Under the DEBUGGING section select Mock Location app
      Catalyst Share 3
    5. Select Trimble Mobile Manager from the applications listed
      Catalyst Share 4 Catalyst Share 5
    6. Revert back to Trimble Mobile Manager - you can now CONNECT and enable the SHARE option to share the Catalyst positions with 3rd party applications.
      The next time you start Trimble mobile manager you need only CONNECT and enable the SHARE option to do this
      Catalyst Share 6
  • 3.  Re: How to configure device to allow other apps to use Catalyst
    Posted 10-24-2018 15:13
    Hi Tom,
    This a bit late but thanks very much.  Everything works great and I'm averaging 1 foot accuracy with a sub-meter subscription.
    Thanks again,
    Richard
